RWKHausSupply
- yorba linda, Cali
65-65.5 WMS for both axles and 5x5.5 bolt pattern..
Front is:
Front axle complete and mocked up to bolt in to jeep TJ and XJ front or remove tacked on UCA and spring buckets for anything else.
CURRIE FABRICATED F9 HOUSING - 3.0 TUBE with DANA 44 CJ INNER C'S with HD lower control arm brackets set at stock TJ/XJ/LJ width. No burned in uppers, but do have one tacked on with a trackbar bracket and coil buckets(tacked on). ($1000)
Yukon Duragrip "street" not "aggressive" Posi 31sp($480)
Yukon 5.83 ratio gears.($275)
Yukon master kit. (275$)
Yukon super bling alum drop out with 10 bolt daytona pinion support and carrier thru housing bolt design (for 3.25 or 3.06). ($389 + $90)
Forged 1310 yoke. ($100)
Yukon 4340 31sp inner Shafts. ($350)
Nitro 4340 GM 30 Spline outers. ($250)
Yukon 30 spline Super strong hardcore hub kit.($370)
Yukon super Joints.($385)
Reid GM knuckles ($500)
High Steer arms ($275)
Fancy Artec D44 Knuckle Bolt Kit ($60)
Centric GM brake parts (calipers/rotors) ($200)
Yukon GM Spindles ($200)
All assembled with all bearings and seals.
$5300 if bought new plus labor and other smaller items not listed.
Will let it go for $4000.
Rear Is:
CURRIE FABRICATED HOUSING - 3.25 TUBE - HOUSING CENTER WITH TUBES AND BILLET HOUSING ENDS. ($900)
Currie back brace ($370)
Skid plate. ($100)
Fill and inspec hole/cap installed ($100)
Currie 35sp alloy axles with bearings seals 1/2" studs at 5x5.5" pattern ($350)
Yukon Super HD drop out with Load Bolt ($700)
Yukon daytona pinion support ($90)
Yukon 5.83 ratio gears ($275)
Yukon 35spline Spool ($215)
Currie 11" disc brake kit ($530)
LCA brackets and Custom Upper center mount (for upper triang) CA brackets welded on ($400).
= 4200 if bought new.
Let it go for 3200$
Or Both for 7000$
Intercom RRP550 rugged radio. and will include enough cable for driver and pass from center dash, helmet connectors. As well as a PTT button - 225$
Motorola Maratrac 110W radio, includes base unit, head unit, mike and speaker, and if you buy it with the comm above a interconnect cable that integrated the radio to the intercom. 100$ or 300$ for both comm and radio and will throw in another radio for only 75$ more for pit to car etc. These reach far.
Pair of 2.5" Fox Bypass Shock, Remote Reservoir, 3 Tube, 16" Travel
New, just received, not going to complete Jeep
These were direct from fox and brand new. Told em for a 1700 - 3700 jeepspeed cherokee rear for valving. All their best seals etc.
Part # 980-02-115
New never bolted up.
$1300 for pair.
Pair of 2.5" Fox Bypass Shock, Remote Reservoir, 3 Tube, 12" Travel
These were direct from fox and brand new. Told em for a 3700 jeepspeed cherokee front for valving. All their best seals etc.
Part # 980-02-214
1200 for pair.
Rock Krawler 2-5/8" race series RRD coil over shocks with Pac Springs 3"ID 14"/175lb & 18"/250lb per shock with dual rate sliders.
2.625 RRD Remote Reservoir Coil Over Shocks
Those but in race series, they are actually race series but in silver to match fox better. But that link above give actual lengths etc.
700$ea typically plus springs. But will let the pair with springs etc All New, go for 1000$pr
Also have one of the most reliable 4.0 stroker jeep engines out there. Its built by Bishop-Buehl Racing - Russ here on the forum. I have all the specs and such if interested. Its about 320HP 93ish octane extremely reliable jeep engine. complete pan to throttle body to header etc. 2600$ for the complete motor. Head alone is worth about this with lots of hours in port blending and polishing etc. see picture.
Corbeau seats and harnesses. Just installed 1 yr ago so some time left on Spec date. 2 5 point 3" harnesses and 2 seats - 550$
Blue and Yellow LED lights (3x2) SUPER BRIGHT for rear facing needs. - 40$ pair.
Rigid Brand new never used 130322 E-Series Amber 30" LED Spot/Flood Combo Light Bar
Amazon.com: Rigid Industries 130322 E-Series Amber 30" LED Spot/Flood Combo Light Bar: Automotive
Sells for 950$ will let it go for 500$
DJ Safety Carbon Fiber helmet - was 900$ new SA 2010 in XL
HELMET, VISORS, & SUPPORTS
http://www.djsafety.com/main page_files/PRODUCTS/HelmetETC/FullFaceCarbonFiberSideVent_LogoMedWeb.jpg
Sell for 350$ has PCI helmet kit installed.
And a NecksGen Original neck/head restraint with the helmet clips mounted to above helmet, - 200$ added to helmet or 275$ alone
3 layer DJ safety fire suit for a 6'5" guy with 40"ish waist and shoulders to match used in 3 races - great cond 175$
Front is:
Rear Is:
Skid plate. ($100)
Let it go for 3200$
Or Both for 7000$
Part # 980-02-115
$1300 for pair.
Part # 980-02-214
1200 for pair.
