- Houston, Tx
I recently replaced my 3-core radiator with another 3-core radiator after my fan went through it due to bad motor mounts. I replaced the mounts as well. Now my Jeep doesn't seem to cool at idle or low speeds as well as it used to. Once I'm moving its as good as it ever was.
Some of the thermal tabs busted off the fan clutch when it went through the rad. Is it likely that the fan clutch is damaged? Could the fan have bent? Or is this something else that coincidentally showed up now?
