GearWrench METRIC DOUBLE END RATCHETING FLEX WRENCH SET
Original_MudButt
$49.99 - That's half off....
These look kind of cool. They are like ratcheting obstruction wrenches.
I did a quick search around their site but could not find the same deal on SAE sizes. Maybe if someone else has the time, they might find them.
Product Description
GEARWRENCH 6PC MET DBL BX END
Ratcheting productivity in places where the fastener is obstructed and/or there is little room to swing the wrench Reaching fasteners behind obstructions or around corners Double box XXL wrench with a lockable joint that allows the box ends to pivot from left to right Combine the benefits of a specialty obstruction wrench with the versatility of a GearBox ratcheting wrench Forged handle for heavy use
Sizes include: 8mm x 10mm - 11mm x 12mm - 13mm x 14mm - 15mm x 16mm - 17mm x 18mm and 19mm x 21mm.
http://www.sears.com/shc/s/p_10153_12605_00918646000P?sid=I0084400010000100675&aff=Y
these are EXTREMELY useful, as you can index the box ends and lock them into place. they make reaching the 14mm nuts on the top of the tcase no problem.
Thanks for the heads up, got mine today! Came in the mail in a huge box, nearly big enough for the mini-fridge I ordered at the same time. I thought, holy poopie, they mailed my fridge, but then I saw it was only 8" deep. :D
