Yellow01xj
- Arvada, Colorado
Would changing out the stock gears on my 2001 XJ to 4.56 or 4.88's give me better gas milage? I am running 31" tires. :dunno:
I run 31's on my manual and 3.56's are perfectDutchVDub said:Actually using the cross multiplication method in the tech section a manual transmission equipped 4.0 needs 3.60 gears to perfectly match w/ a 32" tire. That means 3.56's from an auto equipped XJ's axles would be a really close match.
BTW, correcting your gearing back to near stock makes your speedo and odo more accurate.
philip_g said:I run 31's on my manual and 3.56's are perfect
Why don't you down shift. I have 35s and 3.55s and have no prob running up the mountain at 70 mph.swbooking said:I DD my XJ and drive about 200 miles a week, 4.10s and 35's with an AX-15 suck... Its OK for flat / around town, but the minute you head up a mountain or hill, say hello to all the truckers that pass you... I'll be going to 4.56 or 4.88s on the next set of axles.
To the OP, i wouldnt go above 4.10s. You'll be reving very high on the freeway and it will ruin your milage.
Stang5lgt said:Why don't you down shift. I have 35s and 3.55s and have no prob running up the mountain at 70 mph.
17mpg last tank. I love 5 speeds.philip_g said:jesus. I bet that sucks gas like no other.
