gear problem
If the hub on the ram fell apart there was something else going on. The outer shaft holds the hub togther, the inner shaft give no support at all.
alright, I'll probly do that then, just take the shafts out and disconnect the front driveshaft.
BTW you guys responding so quickly to all of my questions is what makes naxja the best site around. thanks again, I really appreciate it.
yes, you HAVE TO HAVE THE OUTER AXLE STUBS INSTALLED.
Torque that bolt (36 mm bolt) to ~175 foot pounds. If you dont do this, it will be just like that dodge..
