Gas Tank Problem
FlamesFearMe
Whitehall, MI
Is there a safe way to cut the hanger bolts for my leaking tank. It is an 88 and there is so much crap built up that I cannot get the nuts off and there is not much room to do anything with a hacksaw. Is there a way to safely get a grinder in there to shear them off without losing my face?
On my 90xj I had to hammer a socket on the nuts and just twisted the J bolts in half. They broke off pretty easily. Worse case if you can get the gas out fill the tank with water and cut away. A Dremel may work if ya got one?
Just do as Klonestar suggests and shear them off. It won't take much effort if you can get a socket or even a big vise grips on the nuts. In fact the real challenge is not shearing them off. If you can get a file in there, just file partway into the hangers and they'll shear very quickly at the weak spot.
