Shogun
- Arizona Territory
Installed new "long-range" fuel tank (32 gal). Have been noticing that upon removal of the filler cap there is alot of air pressure, way more than ever before. Sometimes I hear the tank pop out.
The tank has one of the two OEM vents installed. I dont know if these are one-way vents or two-way. I suspect it is not operating in the outgoing direction, or the line is clogged.
Due to the fun involved in removing the tank to check/replace the valve I will just test the line. But pending further info, any problem with leaving the cap loose? (non-OBD2)
