- MilkyWay Galaxy
Jeep runs fine, daughter 1000 miles away said she smelled gas odor at rear of the jeep last night. She checked the oil dip stick and she says it smelled like gas, and just now before firing it up still had SOME gas odor in the oil.
She just checked the gas tank lines / rear axle area after a short drive and it was bone dry.
Her nose is not yet calibrated
, and we have already mapped a plan for her to replace Splugs and wires.
That leaves the question of a possible injector issue, but the oil is not thinned out, pressure is real good, 30-50 PSI idle to cruising and running 15W40 in the summer In Col, with 280,000 miles. Runs 10W30 in the winter.
So I am thinking partly tail pipe issue, bad cat converter (thus gas smell idling) and or maybe too many missfires on average making the oil smell some.
But the idle is perfect, smooth, no running issues. So I doubt a fuel injector issue. Starts up supper fast.
So I doubt it is fuel injection issue.
FWIW, I can smell a tiny gas leak two driveways away from me, I suspect she can too. So we may be over reacting.
Any thoughts???? Feedback???
