Gas Gauge Gone Gaga!
Ok, the gauge is a variable resistor, 0 ohms = empty, 44 ohms = 1/2, 88 ohms = full.
You can stop at radio shack and grab a few resistors to test the gauge itself.
Check the resistance value at the tank, you have filled it so it should be high--if not, the sending unit is trashed.
Another possible issue is a saturated sending unit float.
