Full width D44 and 9 in. for XJ
440swepty
Savannah, GA
I have a set of full width HP D44 and a 9 inch set up for a Cherokee XJ. Axles are 1 year old since rebuild, approx. 4000 street miles and 6 trail rides with 7" lift & 35's. Approx. 68" WMS to WMS. 5X5.5 bolt pattern. Going bigger and upgrading to 1 tons. Currently under Jeep. Front will include both spare shafts and misc. hubs/ spindles.
Asking $1500
Details:
Front is a 1976 HP44, 4.88 motive gears, Full Detroit, factory
shafts w/ new spicer joints, includes spare shafts, New steel piston calipers, pads, rotors, bearings, seals and spicer ball joints, T&T customs truss and coil mounts, custom track bar mount, Lower mounts factory width, Upper mount set up for Pass. 3 link but could be easily set up for factory 4 link. Warn premium hubs and superwinch spares. Inner C's rotated for 6 deg. caster at 12 deg pinion angle. Rough Country diff. cover skid. Knuckles reamed for OTK steering.
Rear is a 1976 big bearing 9 inch, factory 3rd, 4.88 Motive gears, solid pinion shim, and spool. Moser axles and bearings, New disc brakes with GM 3/4 ton calipers. Axle shaved, plate over back of ring gear, braced and drain plug. Will include brake lines. Has rough stuff perches and Traction bar mount on driver side.
Great deal but bad timing....for me anyway. Good luck!
great deal wrong state :(
Youre about a month and a half late on making a sale. I just finished my built D30/D44 combo...
no no it is not in my mind its in the fact its out of bounds for me to run on a weekend.
and yes the wallet would be less then pleased too
:huh:
Savannah is only 310 miles from you. Surely you can get someone on that whacked out fixed wing base to let you go an extra 60 miles with a buddy in the passenger seat.
Besides, the seller might make up that mileage if you brought the money.
:huh:
100 miles is a weekend boundary lol and youre killin me! .....maybe tax return, provided they are still avalable............or i could sell off the kid....yea that would work.......
http://www.2maw.usmc.mil/Wingadj/WgO/1050.1XCh1.PDF
Page 4
Weekend liberty is 250 miles for units assigned to 2MAW, unless your particular unit has assigned a special limit. I've never been in a squadron that differs from what wing or MEF has assigned.
YMMV
GySgt James :confused1:
ah see Gunny, my unit is picky about how far we can roam. my Division Chief/SNCOIC puts further restrictions on my shop. 100 miles. any further a special libo chit is required.
and as stated the cash flow of my less that wonderful paycheck hold me back too. i dont make Gunny pay :D
Sgt W. ;)
AND THEY ARE ON A 2 DOOR LIKE MINE!!!!!!
stop teasing me. its not nice
