Full Traction Leaf Springs 6 inch lift
CaliGold
I bought these from another NAXJA member (Fordguy) a couple years back, but never used them. These are from Full Traction's 6 inch lift kit. I believe the springs will give 5 inches of lift. You'll need longer shackles to achieve the full 6 inches from what I read. Please do your research since I have limited knowledge about these springs.
I only want what I paid for them $200. No more, no less.
Available for pickup in Granada Hills 91344 or Hawthorn 90250.
PM's answered in order received.
It's good I measured this a while back.
I was originally thinking of using these springs minus a few lower leaves to stay at 3-4 inches and get a better shackle angle since the springs are longer. That's why one spring pack has a new centering bolt - I was playing around with re-configuring the leaves. BTW, I have another new centering bolt for the other leaf if you want to change that out as well.
The chord length (if main spring were to be flattened) was about 2-3 inches longer than stock. Uncompressed eye to eye is probably a tad longer, but I can't remember well enough to give you a solid number... my estimate is .5 to 1 inch longer.
These seem to be pretty robust - double military wrap for the front eyes, and the bushings seem to be in great shape. Just never had the chance to use them.
No prob. Check this thread when you're ready. I'll post up if someone takes them.
Sale pending. I'll post up when final or if available again.
