I took this week off from work to get this thing ready for the local Memorial Day jeep ride. Missed it last year, wont this year.
Made a pair of bump cans on the lathe.
I used 2" schedule 40 pipe, trued it and cut the ends perfectly strait.
Figured I should plate the body before I mounted anything to it. So I got a 4'x4' sheet of 3/16" and some poster board. Then cut them out with the plasma cutter.
I went to Tractor Supply to pick up some thick steel bushings to make the clamps. Well they are 6 bucks each! x 8 is 48. I could buy cans for that. So I used part of a 2 1/4" exhaust clamp, kinda redneck but they work.
I made mounts and cycled 3 times before everything cleared and lined up.
This is were they ended up working the best.
I initially underestimated the travel difference when you run the bump on the control arm and shock on the axle. I'm sitting 1/4" into the bump at ride height. Not ideal but ProFender claims it will be fine, I may still raise the coilovers an inch or so. Thoughts?
