SikBro631
- Suffolk County, NY
I have an 88 renix XJ. I pulled the engine for an overhaul and as I was taking the injectors out 4 of them broke at the neck into the fuel rail. I need to buy a new fuel rail and put new injectors in obviously. Now, ive done a ohm test on the jeep injectors and theyre saturated. I have a small bucket full of honda injectors (from customer builds/upgrades both peak and hold and saturated) and they are 240cc/22.85lb. I do have a S-AFC installed and a aem wideband so I'm assuming I can use the honda injectors without an issue. I need a 2nd opinion on wether or not anyone would think these injectors will work. Basicly theres no need to purchase new injectors being I have plenty in stock. Only mod I have to do is change the plugs since the saturated honda injectors have jetronic plugs.
