Squidmonkey
- San Diego, Ca
Backstory:
1993 XJ Sport, 4.0 I6, Auto
Few days after Halloween, I was heading to the gas station to get gas, when the XJ Died. had a buddy take me to get gas (figured that I had just run out) Put five gallons into it and it wouldn't start. Had it towed home.
After further inspection, it turns out one of the fuel injector wires and rested onto the exhaust pipes and burnt through, grounding out, shutting the car down. Turns out it fried my fuel pump as well. Replaced it as well as the filter and relay. still would not start. So I did more troubleshooting and research on Naxja, and found that even though the CPS could test good, it could easily be bad and the symptoms of a bad CPS was what I was experiencing. Replaced it, still nothing. Fuel pressure, no spark. Decided to do the haynes manuel spark test. Hold a spark plug coil to ground see if it would spark, nothing. Tried using a jumper straight off the ignition coil, and tapping it to ground see if i could get a spark generated. Nothing. Went to the store, bought a new coil We where getting 12V to the coil, but nothing out of it. Nothing. Baffled. Bought a spark tester just in case the other method might not work, spark tester indicated nothing. Also, my battery was draining pretty quickly, I had figured it was in relation to us constantly trying to crank the XJ. I took a Fluke multimeter and checked resistance between Pos and Neg, with the battery unhooked. 1.2Ohms. Started pulling fuses to see if I could isolate problem. If either the I.O.D. Fuse OR the Fuse Panel fuse are removed, the short goes away. I dont have to remove both of them, just Either of them. I installed both fuses back in and then Removed Every fuse in the fuse box, not just one at a time, but all at once as well, to see if short went away. still there.
Summary:
New Fuel Pump
new Fuel Relay
New Fuel Filter
Fuel pressure at rail is good.
New CPS
New Ignition Coil
Short between Pos and Neg that only goes away when I disconnect I.O.D -OR- Fuse Box.
I'm going to check under the fuse box and see if there is anything there, but other than that, I'm completely baffled as to what I can do to get my car started again. If someone can point me in the right direction as to what to check, that would be awesome. I would normally break down into a wiring diagram and go that way, but the Haynes/Chilton ones are just not that good. What do the I.O.D. and the Fuse Box have in common that would keep my jeep from starting?
Again, i appreciate it,
always seem to come through.
Summary:
New Fuel Pump
new Fuel Relay
New Fuel Filter
New CPS
New Ignition Coil
