CanMan
- Lake Tapps, WA
Old hobbies have sparked my interest as of late, and dont really have any desire at this time to finish this axle and build a 60 front.
Shaved approx. 1.5". Welded carrier, Brand new, never set up Yukon 5.38 gears, Timken/Yukon master install kit(new carrier and pinion bearings and races, crush sleeve, set up shims, ect), Dually hubs(63.5" WMS) with new bearings and races, RuffStuff bolt on disc brake brackets, stock shafts(1.59" 30 spline full float), custom diff cover, no brackets. You will need 1977 GM truck 3/4 ton front rotors, calipers, and dually wheel studs. I can set all this up and finish the axle for you for $50 more, you buy the parts.
Will ship on your dime.
$350
Gears and install kit-$340ish
Weld on plate and shave-$100
Steel for diff cover-$20
Disc brake brackets-$55
Dually hubs-$40
$350
Dually hubs-$40
