cloudswimmer NAXJA Forum User Location So.Cal. Mar 15, 2008 #1 Have a set of Rubicon Express Extreme Duty fixed upper control arms here out of my 5.5" Extreme Duty lift kit.Asking $75.00 PM me or call 949-559-6639 Chris
jeeperjohn NAXJA Forum User Location Temecula, CA Mar 15, 2008 #2 How does the length compare to stock?
markw web wheeler NAXJA Member Location Lakeside, CA Mar 15, 2008 #3 I'm willing to bet they're 15" center to center which is what the stock ones are. The RE kit used drop brackets, so it was effectively a 1.5" lift as the drop brackets lower the frameside mounting point 4".
xDUMPTRUCKx NAXJA Forum User Location highway to hell Mar 15, 2008 #4 ill take em if you take paypal........
Darky NAXJA Forum User Location 29 Palms, CA Mar 16, 2008 #5 The LCAs are same length as the stock ones, but have an offset to the axle end mount that drops them a little bit
cloudswimmer NAXJA Forum User Location So.Cal. Mar 16, 2008 #6 BlackSport96 said: The LCAs are same length as the stock ones, but have an offset to the axle end mount that drops them a little bit Click to expand... Yeah just measured, 15.5" center to center.Looks like Dumptruck found a whole nother rig for parts, so these are still available.
IslanderOffRoad NAXJA Forum User NAXJA Member Location Houston, Tx Mar 16, 2008 #7 where are you located? this could solve the problem of me bending stock UCA's.
Darky NAXJA Forum User Location 29 Palms, CA Mar 17, 2008 #8 Gotta say my RE lowers are a lot beefier than the stocks, and these look good too.
