FS: Low Pinion Dana 30 4.88s Complete
z06elmo
United States
Hello all,
i have a dana 30 with 4.88s in it. has some fairly new cross drilled rotors, refurbed calipers, ball joints are good. longer front brake lines. The 4.88s have only a few thousand miles and are broken in. It's a bolt in axle.
The only negative is that the axle seal on the driver side is leaking and needs to be replaced. Also has a solid diff cover (not pictured).
i'm willing to part it out, or you can take it as one piece. it's complete end to end. Location: Santa Clara
$350?
Danny
is that the IRO steering? crazy how the drag link goes UTk like that and the tie rod goes OTK.
