FS- Headlight relay upgrade
Status
Not open for further replies.
chpmnsws6
Springfield IL
Needless to say, the factory XJ headlight wiring leaves much to be desired. I bought a few kits, one for the XJ and one for the Miata, but the Miata didn't need it, so its been sitting around the barn for a few years.
Get full juice out of your headlights and leave the factory wiring up to the task of turning on a relay.... .5amps at most of power vs 10-30 amps for the headlights.
10 shipped within the 48 states.
Looks exactly like my relay, it is easy to install, the hard part is routing the wire. I ended up taking off my front grill and things around it, but I did it myself. The harness is such an amazing upgrade I wouldn't hesitate to do it in any XJ ever! The ends are plug and play, the relay's are screwed into the engine bay somewhere. Just tape up the drivers side stock headlight plug (just incase it gets water or something in it). You plug the stock passenger side to the wiring harness. You also take out two fuses in the fuse box, but I forgot which ones.
Status
