FS / FT TN: Tow Rig: 1997 Ford F-250 Diesel 4x4 w/ Dana 60 swap
XJ_Otto
Nashville, TN
1997 Ford F-250, just rolled over 180K miles.
Almost entirely stock. Never had a chip or a programmer. 3rd owner. No rust. No tears in the seats. Brake controller and factory tow package. 2 new batteries in May. Year old alternator. PO replaced torque converter. Fresh oil change, fresh fuel filter change. I have a stack of receipts with more. A/C blows cold, heat blows hot. White with grey interior. Excellent condition. Tires are better than 90%. Never towed a 5th wheel. Driven less than 16K miles in two years. The only "modifications" done to it:
Dana 60 swap from a 1997 Ford F-350. New seals, shortened front driveshaft, new u-joints in the axles and the driveshaft, new leaf spring bushings, aligned, swap done correctly. No more TTB Dana 50 mess up front.
Barnone E-fuel kit. No more mechanical fuel pump or expensive OEM filters to buy.
Bad: One of the lights behind the tachometer is out. A trim piece on the hinge on one side of the middle front seat is broken off (I have the broken piece). That's about the worst of it.
You will be hard pressed to find a nicer OBS diesel. The modifications to this truck just make it a better truck, but it is otherwise stock and unmolested. Its 20 years old so its not PERFECT but its close...haha. Shoot me an email and I can get you more and better pictures of whatever you need. jetmechpilot(at)yahoo(dot)com
$14000 OBO. Will also trade plus cash from you for a clean mostly stock Cherokee. Must be auto and 4wd. 97 or newer, prefer 97-99, but will consider 97-01. Selling b/c Im getting a second degree and I have to hit the highways a lot. Will get more pics up soon. Email jetmechpilot(at)yahoo(dot)com for faster response. Thanks!
$14k? KBB shows this truck just over $9K in excellent condition.
Hello Brian.
#1. OBO
#2. KBB isn't a market indicator. I had a 2004 STi that KBB told me was worth $23000 two years ago and I sold it for $17k b/c that's what the market supports.
#3. Honestly, I'm not expecting to get $14k. But look around and find me a truck like this that is listed for $9000.
