FS: Fox 3.0 Factory Series Triple Bypass Piggyback Shocks w/ 18" of travel
the_midwesterner
Evansville, IN
Posting this for a co-worker of mine.
History: Shocks were purchased to use in a desert Tundra build with a through-the-bed shock hoop. Plans have changed and shocks cannot be used with the new canter-lever setup going underneath the bed.
Cash Price:$1800, firm
Condition: Brand spanking new, still in box
Trade: Willing to trade, straight up, for similar 3.0" Fox Shocks in 12" travel with Triple Bypass and Remote resi's.
Please contact: [email protected] or PM me for cell number to text
Pics are at the bottom
**From the FOX website**
Overview:
FOX bypass shocks continue to dominate offroad racing with their unmatched performance and ease of adjustability. Combining the finest materials available with continuous, real race testing delivers the unrivaled performance that FOX is known for. The position-sensitive external bypass design allows for each stage of the shocks compression and rebound stroke to be adjusted independently from the others without affecting the other stages. FOX offers custom bypass tube layouts to maximize your suspensions performance while adhering to the vehicle's space restrictions.
Specifications:
Body
Smooth-bore, clear coated, zinc plated, honed seamless alloy bodies
Components
Black anodized 6061-T6 billet aluminum
Shaft
7/8" hard chrome plated stainless steel 17-4 H900
Piston
Race-developed high-flow piston design
Valving
Proprietary deburred valve shims
Seals
Redundant sealing pack system main seal, wiper seal, scraper seal
High temperature Viton seals
Oil
FOX formulated for ultimate performance at variable temperatures
Reservoir
Piggyback
Optional remote reservoir
Mounting
Lined, heat-treated, alloy steel spherical bearings 1/2" bolt x 1 1/2" wide
Adjustments:
Compression bypass adjusters
Rebound bypass adjusters
Free bleed bypass adjuster
Nitrogen pressure
Compression valving
Rebound valving
Pics:
