FS: Factory Tow Hook, Bumper, Fog Lights
FinalBossX
O.C./S.D.,CA
I just put on a new bumper so I have a few factory parts from a 2000 Black XJ for sale.
Factory Black Bumper with end caps - Make an offer. Any offer. I have no room for this stuff.
Factory Tow Hooks w/ Brackets - $75
Factory Fog Lights - $50
I'll give the fog lights and the bumper to anyone who can help me install my MORE motor mounts. =)
-Mike
Front bumper or rear? I crushed my rear bumper on a rock at Calico...
Where are you at? Hopefully I'll be in HB this Sat, maybe I could stop by and pick up the rear bumper.
I'm in Garden Grove and have a rear bumper (two actually) you can have if you want. I ripped the end caps off to access the bolts easier but they are still usuable or use yours. They are off a 93 and are black.
Hmm are the factory tow hooks and brackets still up for sale.
I'm lacking front recovery points
pm sent
The 97+ brackets are different than the 84-96 parts. The bumper mount is welded to the tow hook bracket, and the 97+ bumper brackets are different than the 84-96 parts. Just an FYI if you have an early body style.
Oh i see so they wont bolt up ............. DAMN
Thanks for the heads up Mark.
Factory Tow Hooks w/ Brackets - $75 Fits only on 97+ XJs.
-Mike
They'll bolt to the frame and work as tow hooks, but the bumper won't bolt to the brackets. The aftermarket brackets by Custom 4x4 are the same, but don't include the bumper bracket, you just reuse yours. I cut the bumper brackets off a set of stocker 84-96 brackets that I sold to Elias, not hard, but not the most time effective thing to do either. He still had some grinding to do on the remains of the weld before he could use them. Not impossible to adapt if you have a grinder and feel like grinding the welds for the bumper bracket. They probably did that to speed installation on the assembly line. If you need a set grab some from Custom 4x4, they'll work with all XJ's. Oh, and avoid the Rusty's ones, as they don't have the extra bracing.
-Mike
is the bumper still availble? if so PM me I can pick friday
