IndyXJ
Member #1314
- W.O.P.R. command
Well, with the baby on the way, and taking some tiime off when he's due(some of it unpaid), I've decided to sell afterall, no regrets. I just don't have the time or want to keep putting money into this Jeep for now.
$5750 no trades or parting out
1999 Jeep XJ automatic AW4 with 4.0
94,800 miles---it's off because I had it regeared to 4.56 in January of '06 but never changed the speedo gear. I would put it at a real world 91k miles, but that is a guess.
4.56 gears
Lockrite in front-January of 06
Powertrax in back-January of 06
High Pinion D30
Chrysler 8.25 (29 spline)
6" Full Traction long arm lift --summer of 04
35" Goodyear MTR's --summer of 04 I have one as a spare but all have seen trail and road use. Tires are of various condition. Some have fine line cuts in them, some have a few chunks out. Also some wear from the steering being off, but you'd have to see for youself to make a judgement.
AR767 black rims that the tires are on.
SYE with High Angle Driveline rear driveshaft. It was rebuilt by a driveline shop in the summer of 2007. New ujoints installed, balanced, painted.
Rear hitch with towhook in the receiver
Front towhooks and brackets
CB
Optima red-top battery-Summer 07
NEW catalytic converter Fall 07--due to theft of the cat while parked in Indy!!!
NEW muffler Fall 07 -replaced the rotting stock one.
NEW Currie steering setup and Old Man Emu steering stablizer.
I installed this after I thought I'd get back into wheeling. NEEDS ALIGNED AND ADJUSTED MORE. I gave up on it since I'm selling it. Don't want to mess with it anymore.
Rocky Road Outfitters rock rails-have some rust and I spray paint them periodically but definitely paint peeling off.
MISC I will throw in--
Spare 8.25 shaft
Spare D30 Stub and I THINK I have the longer shaft too.
Used/junk bearing assembly to get on off the trail(not for permanent use!)
The old stock steering from when I replaced it with the Currie setup.
Barely used Hi-Lift
All my unused diff fluid of various weights
Towstrap in excellent condition
I have wheeled this in-Rockport, TurkeyBay(LBL), Badlands, Haspen and Redbird
Areas I want to bring up--leaky steering box. Weeps with occasionaly dripping to ground, but doesn't run dry. Will need replaced. Leaking again.
A "clunk" when turning slow lock to lock at the end of the turn. I think it's the steering box, but might be wrong.
Front passenger door has a cave in. It has a Lexan/plastic window. Damage from a trip to Turkey Bay a couple of years ago! You will see in pics.
Manifold leak, famous on the 4.0's. Exhaust sounds a little raspy from stock.
NO ENGINE LIGHTS or CODES EVER THROWN in the time I've owned it since 04.
That's all I can think of for now. Please email me at--
[email protected]
Trafalgar, Indiana 25 miles south of Indy.
I will be happy to answer any questions and I've listed any known problems that I'm aware of.
Thank you,
Bill
Jeep video at cold startup
4.56 gears
High Pinion D30
CB
Spare 8.25 shaft
Barely used Hi-Lift
[email protected]
Thank you,
Bill
