91XJMA
- Fitchburg, Massachusetts
'91 Jeep Cherokee. 160K on a 4.0 automatic with an np231 w/ an advanced adapters sye and tom woods drive shafts front and rear. Motor has recent rear main seal, oil pan gasket, valve cover gasket, Rusty's air intake, Rusty's tb spacer,starter, high volume oil pump, alternator, tune up, water pump, thermostat and housing, brakes front and rear, front wheel bearings, axle shaft u joints and seals. Front is a high pinion dana 30 w/ 4.56 gears open diff, Rusty's adjustable track bar w/ hd mount, Rusty's crossover steering, new clevite bushings. Rear is a Chrys. 8.25 with 4.56's locked. Suspension is custom built long arm roughly 8.5" Front is 8.5" coils rear is 4.5" springs, 1.75" greaseable shackles, 2" solid block. Extended SS brake lines F/R, long travel shocks. New exhuast cat back(including cat) with flowmaster 40 series 2.5" pipeing. Custom build long arms from 1.75"x.250 wall DOM. Lowers have DOM sleeved poly bushings on the axle end, and Ballistic FAB joints on the crossmember end. Short arm have adjustable heim joints. Has Rusty's flex flares and a custom rear bumper. I run spidertrax 1.25" wheel adapters to gain some track width and to run 5x5.5 wheels. I have a set of 5 matching wheels and 5 35x12.5x15 BFG M/T's with low miles on them.
So that's all that I've put into it.. The bad, well the speedo quit on me a few weeks back most likely the sensor. The floor on the drivers side needs to be patched up. Both sides are solid just a couple small patches would seal it up. Could probably use a heater core, it blows good it just doesn't seem as hot as it should be. It could use a front bumper. Other than that its a solid 2 door. Passed MA inspection no problems as it sits.
Looking for 2,500 or best offer. Make me an offer, you all know what's it worth so a fair offer would be appreciatd.
I need it gone. Just bought a new truck so this HAS to go. I have more pictures if your interested..
![JPSPD017.jpg](/proxy.php?image=http%3A%2F%2Fi305.photobucket.com%2Falbums%2Fnn228%2Finnocentsweetness82%2FJPSPD017.jpg&hash=d83c820656b8360d8fe810616cc98568)
![JPSPD015.jpg](/proxy.php?image=http%3A%2F%2Fi305.photobucket.com%2Falbums%2Fnn228%2Finnocentsweetness82%2FJPSPD015.jpg&hash=4dabc87452aa8fa20065a75be1c9408a)
![JPSPD014.jpg](/proxy.php?image=http%3A%2F%2Fi305.photobucket.com%2Falbums%2Fnn228%2Finnocentsweetness82%2FJPSPD014.jpg&hash=4dbcccc87020f6d407932c892e44cf65)
![JPSPD018.jpg](/proxy.php?image=http%3A%2F%2Fi305.photobucket.com%2Falbums%2Fnn228%2Finnocentsweetness82%2FJPSPD018.jpg&hash=ab4e8751a1dff1ea1c3845333b92ed19)
![JPSPD016.jpg](/proxy.php?image=http%3A%2F%2Fi305.photobucket.com%2Falbums%2Fnn228%2Finnocentsweetness82%2FJPSPD016.jpg&hash=de0c7e57ced270c0fe6177c69a1b98e1)
