FS: 231 tcase $150
GrimmJeeper
Gardena, CA
quoting justin here for clarity. all i want out of it is what i payed for it 2 weeks ago. money is tight and this has to go.
xjjeeper19 said:
should fit 95 and down 23 spline input, could be changed to 21 spline if it seals the deal . it's in redlands, it will be here till i move to highland in a few weeks. but either way we can get a parts train going if needed. it does still need an output seal.
xjjeeper19 said:
it needs the output seal, available at pretty much any parts house for a few dollars. if need be i'll ship you one if that's all that is holding you back. also, i assume justin has the mechanical and electronic speedo parts available for whichever way you need it.
big thanks to justin for rebuilding this thing for me twice, just for me to sell it like an ass ;), and thanks to rambo for hauling it back and forth for me.
if there is anything else you need to know dont hesitate to ask. i need this gone ASAP thanks guys.
-G
How recently was it rebuilt? What was replaced?
well i guess i should say re-assembled. it was converted to 23 spline so i could put it in my rig, then taken apart and reassembled to use electronic instruments instead of mechanicals, because it was mechanical when i recieved it and my jeep uses electronics. aside from the main shaft i dont think anything was replaced, but if something was out of whack justin would have noticed it.
Thanks.
Mine has some slight chain slop and I have an SYE sitting at home to install, was thinking a bench install would be easier, then throw the whole case in.
I'm trying to remember what my speedo setup is, I know it uses a gear since I changed it.
I do not have a speedo for it, but you can use the one from your jeep when you put it in. even if you have the old cable driven speedo it will still work with that setup too.
Justin
