z06elmo
- United States
Hey Guys,
Posting my car up for sale. I really have no idea what to ask but would like $10,500 for it. Please let me know if you guys think i'm way way off base, but this car has been good to me with a lot of the right mods. I'll post better photos in a bit. Located in Santa Clara. You can email me at dnguyen 81 @ gmail or PM
I have owned this jeep for about 4 years and have done 90% of the mods to the vehicle. I currently rarely have time to go to Hollister and in the last 2 years it's been a mall crawler or tail-gate vehicle. With the 49er's moving to Levis, I'm not going to Tailgate anymore either.
I'm going to try to be as detailed as possible in this description but I'm going to likely miss a lot. The car is setup pretty well. 5-speed XJs are very rare especially for this model year (last year of the XJ). On road it's a more engaging and drive than the 4 speed autos.
Vehicle Details:
2001 Jeep Cherokee Sport. 5 Speed, 150xxx Miles, Clean CA Title in my name
Axles (easily 6K Plus into these)
Rear Dana 44 with Factory 10 Axles (Have Factory Spares) ARB Rear Locker, SOLID rear cover 4.88 Gears
Front Polished High Pinon Dana 30 with Warn Hubs and Warn Axles (Have spares). ARB Front Locker. Upgraded VanCo Big Brake Kit which I believe are WJ Duel Piston Calipers with thicker larger rotors. It's using Magic Pads but I have some extra pads too. Custom Truss and Crane Cover, 4.88 Gears. The front axle was built by a well known magazine editor and is as polished as you can get a Dana 30 front.
Tom Woods Rear Drive Shaft
Custom Front Drive Shaft
Rubicon Express Slip Yoke Eliminator
Suspension/Steering:
Iron Rock Offroad Track Bar, Iron Rock Offroad Steering Kit, Rough Country Long Arm Front Kit with Curie Joints (not the cheap RC ones). 6.5 Inch IRO Springs. OME Front Shocks with Pin Re-locator. Custom Made Sway Bar Disconnects
Rear has Rubcion Express Leaf Springs with OME Shocks mounted on cut and remounted shock struts for clearance
Upgraded to a WJ Power Steering Pump with Durango (the better one with more ratio) Power Steering Box. Also has a power steering pump brace.
Wheels/Tires
Running on 35" Discoverer Cooper Tires with Steel Black Wheels. I have a full size spare as well.
Recover/Armor
ZJ Gas Tank Skid Plate, Lizard Rock Sliders with custom welded on Step/Guard, Bushwacker Flat Flares, ARB Front Bumper with a SmittyBilt XRC 8000 winch inside, 100 Watt Lights, Rear bumper is a semi custom detours USA swing out carrier bumper. I don't have the carrier on due to the weight savings. Also have a Thule Rack on top with a basket
Other Stuff:
K&N Filter CARB legal, Flowmaster Muffler with some rigged pipping going out the back, Sony Stereo with an Amp for the Subwoofer in back in a custom enclosure for the XJ. Has an upgraded Alternator I believe 140 amp model from a ZJ. I had to machine down the bracket a bit to fit. Changed out the radiator, water pump, and the belts a few years ago. I also have the upgraded Cable and battery kit from a member on
. This puts one large fuse i line, and gives better voltage to the battery, starter and fuse box.
Issues:
The switches sometimes work or dont on the driver side. I would have to manually lock or unlock doors. The headliner is beginning to droop. The paint is okay but not great considering hte car spends much of its' time outside. However it presents fairly well and has never been in an accident. the clutch neutral switch is acting up so I bypassed it. There is a leak in one of the AC pipes so it's not charged. I have new pipes to install.
I am open to trades and reasonable offers.
Vehicle Details:
Wheels/Tires
Recover/Armor
Other Stuff:
Issues:
