ratboy93
- alta loma, ca
Guy,
hey i did the math this morning on your front end.. you will be able to run a 14" 7100 short body up front. the one big thing you will have to do is space the bump stop down 1.36"+- .12"( so you dont bottom out the shock).
7100 14 short body is ext length= 33.34 and col= 19.61
foa 10" that the car was set up for 28.25 ext and 18.25 col
now the front end is already setup with a little under .5" of shock left at full bump.
so all you would have to do is add a sleeve over your bump thats the same size as the can thats a 1.36" length and slap on a set of 14" short bodies and BOOM 14" of travel.
that front end has enough brake line and everything to be able to do it.
just look at the driveline idk
