[email protected]
Hey all. ok i just assembled the Front Dana 30 High pinion ring and pinion.They are 4.56 dana spicer gears. According to Randys ring and pinion my backlash tolerance can be from 6-10 thousanths of an inch. I am at 10 thousanths. i know its a little loose but the only way for me to make it tighter is to buy new bearings. I have no way to take the bearings off with out destroying them. Tell me what you think of my pattern and any advice you guys may have. Ring gear bolts 55lb/ft bearing caps 65lb/ft and preload is 13lbs/inch Thanks
