i dont know if those are the same as my 89', but I put longer bumpstops in, and the are a Major PITA to get them back in... if you dont have to take them out, I wouldnt...
As long as you have a good pry bar handy it is not hard at all. But if all you are adding is 2" pucks to a stock suspenion thier shouldn't be a need to remove them all.
I used a big flathead screwdriver to pry the bumpstop out and against the installed spring to push the bumpstop back in. And yeah, you won't have to compress the spring nearly as far w/ the bumpstop out.
