front axle?
OregonXJ
Dallas,Oregon
Well im gonna be upgrading my front axle.I have a dana 60 rear and want to know what a good front would be.Also what donor vehicle should i be looking under.
I am assuming an XJ by your signature, an HP 44 or 60 would be nice but unless you want to go full width it will be expensive. I also assume the 60 you have is full width so maybe that is the way you are going, if that is the case a HP 44 can be had around $400-500 around here when found, aren't really that expensive. An HP 60 on the other hand is very expensive no matter where you are.
Dan Fredrickson
