Front axle shaft replacement q's
w_howey
The Mudwest
My Driver's side axle shaft is in need of replacement.
The U-joint started barking really good in the mud today, and the standard assess the damage walk around revealed a leaking axle seal on the same side.
I have never changed one on a XJ before.
On the Ford, all it took was, remove wheel,caliper,hub. Slide the shaft back and then down and out. Then reverse it.
I know the solid axle tube makes a difference but does it make a huge one?
Any other work I should do when I have everything apart?
Any special tools required?
It's pretty simple. Remove wheel, caliper, Hub nut 36mm, 3 12point 13mm bollts. Might need to use a flat screw driver, to separte the hub/bearing unit , from the knuckle. Then you can just pull the shaft out. Install is just the reverse, just becareful sliding the shafts in & out, so not to damadge the seals. Other work? If you want to install a traction device, your 1/2 way there, as you'll need to pull both axles to get the carrier out. You could check the brakes, & if you want get some of those DTS axle seals.
Rob
