I came across a couple boxes of XJ stuff I no longer want it nor want to deal with selling it.
Basically its everything you need to put a manual trans into a 97+ i pulled it from a "you pull it" yard years ago to body swap my rusted 94 into a 98 donor. I have a buggy now so thats done with. Also some Comanche cab vents, front brake calipers, another pcm, some wiring from door plugs to make quick disconnect doors also not pictured is a Rubicon express track bar bracket, some rear nut strips some rear spring plates
Its all free first come first serve.
David
David
