Mudderoy
- Katy, Texas
The Detours uni-body stiffy's dont wrap the uni-body, they run parallel with the unibody tieing the front and rear suspension points together as well, rosett or plug welds are also used in the center sections of stiffener to tie it to the uni-body in stratigic areas. Their fit is tight & snug to the undercarriage.
The rear suspension tie in or mounting point, dramatically helps the weak factory spring mount from tweaking over time and can also help reinforce already tweaked XJ's.
Our approach to the stiffener is much like the approach found in drag racing since the late 60's and still sold today, used today on modern uni-body racers. (subframe connectors)
We also offer a long-arm version which changes the front lower control arm connection to a weld connection, unfortunitly.....it can't be used with all LA kits. (RE for instance)
Combine our stiffeners with our slyders, you've boxed the entire side of your XJ, they're also offered as a bolt on version, eliminating any welding.
Here's a quick pic of 'just the stiffeners as the would ship.....(XJ~3)
Great, now I need to get the slyder as well. :yelclap:
