jeepdreamer
- Ft Myer, Va
The background: 2001 classic.
Following my 0331 head crack which resulted in a massively cracked block I did a motoclassic.After months of careful assembly, cleaning and painting i finally got it all together an installed. The big day finally came where I was going to fire it up. Put in oil and transmission fluid, easy peasy. Go to put in antifreeze and it comes pouring out. Seems the rear engine freeze plug want good. Just my luck I get to drop the tyranny again.
Next day I come back to the shop thinking today's the day. Once again go to add antifreeze only to disbelievingly see it coming out Again! This time from 2 (wtf!?!) on the block under the intake/exhaust. Pull those and have to order them because nobody had them in stock...3 day wait. In my frustration I decide to move onto something else, something supposedly easier, to feel better. Somehow what started as installing the t-case shiftier ended with me gutting the entire interior.
. Found surface rust on the floors under a very nasty carpet so suddenly I was neck deep in repair work.
I mention all the above to give context of this ill project gone wild as well as my long suffered difficulties so far.
So a few days ago I once again return to the dream of hearing it fire up. Check it all over for the ten thousandth time, drop in a battery and hit the key.
Motor turns over , no odd sounds or spraying fluids, but it doesn't roar to life as hoped.,ok... Check the dash and see the dreaded noBus on the odometer. I've never experienced this so spent a goodly while searching online for explanations.
4 days of googling, trial and error, and lots of gnashing of teeth with no joyful first start. Tested the crank sensor and all its wiring. No resistance. Thoroughly inspect, reclean, and secure all the grounds. Even go to the extent of making new +&- cables from some 0 ga wire.
Also added extra grounds to tie the dipstick tube bolt, the 2 front block bolts,etc so I'm confident in good on grounds.
Long story short... I discovered that my no bus came from the airbag module which normally mounts under the center console. Remember where I said I gutted the interior? Yup... Seems that that module grounds to the tyranny hump.i had it out in prep for bedliner...found it by pure accident!
So with it in i crank the key and SURPRISE! No bus is gone! Cool, right?
Well...no.
While its still offering no noBus it also still won't fire.
In honestly about at my wits end. Hooked up the snap on scan tool but it went/cant communicate with the jeep.
So I would greatly appreciate any thoughts or ideas you guys could offer me.
Help!
Well...no.
Help!
