Ford HP D44 w/ 4.10's
Simms
Mooreland, IN
I have a complete but apart High Pinion Dana 44 with 4.10 gears and flat tops 8lug I'm wanting to get rid of.
$250
I also have a setup to make it 5 on 4.5 bolt pattern to run late model Jeep wheels (ie: keep your stock bolt pattern) which includes flat top knuckles, hubs and bearings.
$100
Buy both for $300, and to keep 'stock MJ/XJ/TJ/YJ/ZJ width' using the D44 you would just need to cut down the long side tube and use an early bronco inner shaft.
I also have another FS up for an 8.8 w/ 4.10's and LSD which would make an AWESOME setup under any Jeep!
Mooreland, IN
317-430-5453 call or text
What are you looking for for that and is it setup for an XJ?
Yup! aside from new rotors and pads...
Cool, I may end up buying that if you have it after WF!
Hot Rod - Yes...
Fatwreck - buy it and you'll have it... ;)
I was more just curious. Are they scout parts?
I would actually love to have the axle, but I'm not in a good place to buy it right now. I need to get my rig driving first....more upgrades later.
no scout parts here...aren't they pass drop anyways?
Ford F-250 axle with 1/2" tubes!
