Ford 8.8 with all the fixin's
Red_daggsXJ
I got this rear end to swap into my Jeep XJ, but now I'm selling the Jeep and no longer need the rear end. it's out of an Explorer and that year came with dic brakes. I have EVERYTHING you need to do a swap ino a Jeep XJ. When I pulled the rear end out I made sure to take as much of the E-brake cable as I could so install would be easier, all you have to do is tie the jeep cable into the e-brake cable to set that up. Other than that, to install this all you need to do is throw it unter your rig, set your pinion angle, make sure everything is square and even then weld the new perches on, and bolt it in. I have the stock plates for the u-bolts, and was going to re-use them and just cut off the shock mounts and weld them back on to the rear end housing somewhere. This is an easy afternoon of work, the only thing you'll need to get are the diff cover bolts, some RTV, and gear oil.
I have a bunch of pics, email me if you want them, or call Cliff:
714-656-7580
[email protected]
Item is in Orange County, CA: no shipping unless you arrange everything, I'm a little busy.
Price is $500 Firm, there is more here in all the parts, I just need it out of the garage.
Here's a list of all the parts:
Spicer Yoke adapter
Currie Enterprise U-Bolts
Drilled & Slotted Brake Rotors****
New Spring Perches
New Brake Pads
