Ford 8.8 FS
sallys xj
Arizona
Like the title says, I'm selling my ford 8.8 to make room for a 14b to complement the front axle.
Ford 8.8 is used and has been great with zero issues during the 8-9 races we entered in 2013 plus the weekend trips.
8.8 is running Yukon 4.88's locked by a spool and turning chromolly shafts and protected by a SOLID dif cover..
comes with spare shafts and will toss in the u bolts and top plate with incorporated bump stop strike pad
This axle has MORE brackets for the spring perches and C-rock lower shock mounts set up for my XJ could add different lower shock mounts if needed.
This is a drop in ready to run axle for a Cherokee.
new would cost 1300 to build with parts and spares
asking 800 as is
or a 1000 to replace seals, fresh oil and factory style shock mounts.
pm or text/call at (nine 5 one) 7 four 1- two 1 four 9
Matt
