- Port Orchard, WA
after reading this thread - i wondered if a winch truely does put more tention on a tow point than a strap.
http://www.naxja.org/forum/showthread.php?t=44725
here is what i found...
High school physics will tell you that force (F) = Mass (M) x Acceleration (a)
therefore f=ma
the mass of my XJ is around 3500lbs which is a weight and not a true mass measurement. Therefore we have to convert that into a mass measurement - Kg or Kilograms happens to be one and 3500lbs = 1590kg.
we are calculating the line connecting the system, so we have to double the weight because there are 2 XJ’s that will be accelerating and we get 3180kg.
My acceleration from a dead stop can be formulated (assuming that acceleration is constant - which its not, but ill consider the change in acceleration from when the strap has tension till the vehicle is either moving or your JC Whitney hitch pin bends negligible) via the 1/4 mile time for a stock Cherokee (which with my 28.5" tires and stock gears it is) from a search on this page Dragtimes
ok so we have the equation from physics class of:
final Position (X) = Initial Position (X.) + Initial Velocity (V.) x final Time (T) + 1/2 Acceleration (A) x final Time (T)^2 or time squared
looks like this:
X = X. + V.T + 1/2AT^2
since I will be using the 1/4 mile time to find the acceleration, I’m going to set up my plane to use Start as 0 therefore X. = 0 and since we are starting from a stop, initial velocity = 0 therefore V. = 0
and since I’m using metric units above, I need to convert 1/4 mile into meters which is about 402 meters.
so our equation now looks like:
402 = 0 + 0(15.2) + 1/2A(15.2)^2
simplification that we learned in 6th grade gives me an acceleration of:
3.5 m/s^2
now we plug this back into our F=ma equation and get the force on your "Pin cure all cheap tow point"
F = 3180 x 3.5 then the force on that pin is 11310 kg x m/s^2 or 11310 Newton’s.
now we convert back into pounds, (1 Newton ~ ¼ lbs of force)
[font="]2782 lbs of force.
[/font][font="]ok - where did i mess up? or is all that fairly correct?
[/font]
therefore f=ma
looks like this:
3.5 m/s^2
[/font]
