BigDirtyCrew
- Brighton Co.
Built hybrid tube crawler. Started life as a 90 XJ. Now to the important part, Parts List:
1. Full PSC Hydro Steering with cooler and extra large fluid res.
2. Secondary electric fan with selectable toggle switch in dash.(Never run hot)
3. Ford Dana 60 High Pinion Kingpen front axle with 5.38 gears and ARB air locker.
4. Crane HiClearance Outer knuckes and HiSteer arms. With SE60 spring eliminator kit.
5. Yukon 4340 chromoly 35spline inner and outer axles in the front with CTM's!
6. New Trail Ready 17x9 HD aluminum beadlocks.(3 trail runs)
7. New Super Swamper Iroks, 39x13.50x17 (3 trail runs)
8. Rebuilt 4.0L with AW4 tranny.Cold air intake, 2.5" header with full new exhaust.
and yes, I have all pics of rebuild and all internal work.
9. ATLAS 4.3 2speed transfer case.
10. Tom Woods drivelines front and rear with spare F/R drivelines.
11. 3link up front with Coils and new Bilstein 5100 shocks 14" travel.
12. 4link rear Ford Dana 60 with truss and 5.38 gears with spool. (30 spline axles)
13. Radflow 12" coilovers in the rear revalved and rebuilt this winter.
14. All links have RockKrawler joints fully cleaned and rebuilt this winter( extra joints)
15. Front and Rear disk brake conversion with larger ford master cylinder and SS lines.
16. Warn 8000k winch with controller.
17.Full rhino linnned tub with floor mates.
18. Wet Okole waterproof seat covers (wet suit material)
19. Grant steering wheel and custom console for tranny shifter and tcase twin sticks.
20. It does have a brake cutter so you can front dig with the Atlas Tcase.
21. Optima yellow top deep cycle battery.( great for winch operation with aux. lights)
22. KC 6" 100w trail lights with LED brake lights and turn signals.
23. Wheelbase stretched to 108" with a 22" belly heighth. ( low slung for vertical climbs)
24.Crow 4 point harness for the front seats.
25. AC compressor conversion On Board air system for airing up tires or air tool's.
26. Solid industries 35spline front drive flanges for the front end.
And much more. This is a purpose built rig that will go just about anywhere with ease. This rig is complete ready to go wheeling so no work is required. Everything was fully rebuilt and all services completed threw the winter. I am not interested in trades or parting out but do want to see this rig go to a good home. Asking $10,000.
