For Sale 1999 Cherokee XJ Two Door 4x4
Zyman
Located in Johns Creek, GA 30005. https://www.ebay.com/itm/297067860704
$12,000
1999 Jeep Cherokee SE 4x4
Purchased on January 4, 2024 with 121,169 miles. PS, PB, PDL, PW, AC. Since purchased the following maintenance or replacement has been performed and items added:
Replaced:
  • Spark plug wire set, cap, & rotor, spark plugs, air filter, Radiator, radiator cap, coolant, all coolant hoses, hose Clamps, Thermostat, coolant, Serpentine Belt, Trans fluid, transfer case fluid, wiper blades.
  • Cigarette Lighter.
  • Shocks with Bilstein 4600 series shock part numbers 24-141727 and 24-141734.
  • Steering stabilizer Mevotech MS409123.
  • Driver side power window switch.
  • Front license plate bracket.
  • Exhaust system MBRP Armor Lite Series Exhaust S5534AL
Added:
  • BOSS Audio BE8ACP-C (head unit 8” touch screen with Apple CarPlay and Android Auto, back up camera).
  • Accele USBR2X (USB Port for head unit).
  • Kenwood KFC-P710PS (6.5” component Speakers).
  • Rockford Fosgate P300-10T Powered Sub-woofer.
  • Compustar 752A (Alarm system with door remote)
  • Jeep Full Instrument Gauge Cluster with Tach (shop recalibrated to correct mileage), also replaced all the bulbs in the unit prior to installation.
  • Spectre Performance 9051 cold air intake.
  • Rough Country lift kit, 1.75” front, 1.5” rear.
  • Vision Soft 8 Wheels 16” x 8”
  • Kuhmo Road Venture A/T 52 Tires 245-70 R16 (installed at 125,106 miles).
  • HWSTAR 2022 LED Headlights (amazing improvement over stock).
  • High Performance 3M Window Tint.
  • Husky Front Floor Liners Classic Style Series, Black 30101.
Extra Parts Not Installed (included with sale).
  • Fog Light Wiring Harness.
  • Fog Lights Switch
  • Front stabilizer bar drop links (using stock now, but these aftermarket units are better for the mild front lift).
  • Front passenger seatbelt. Original belt occasionally seizes not allowing it to pull out to buckle.
The Good
  • The interior is in great shape devoid of any funky smells, firm buckets, all seating surfaces free from rips or stains, headliner excellent, carpet great, dash and doors excellent. Center Console in great shape but someone disassembled it and did not refasten with all the screws, it is stable but needs to have some screws added.
  • Runs, and drives very well. The 4.0-liter motor is bulletproof and is at less than half its useful life.
The Not as Good
  • The car spent it’s first 25 years in the St. Louis area and has had rust repair. Repair was amateurish and not holding up well (see photo of right rear quarter in front of wheel opening).
  • Paint looks fine in pictures, but has plenty of flaws, chips, hail damage, and overspray from touch up paint. Basically, a solid classic Jeep meant to be driven with the patina.
  • The Oil Filter Adapter O-Rings need to be replaced (FEL-PRO ES72962 for $3.25). The adapter drips oil, not enough to move the level on the dipstick between oil changes.
