Ecomike
NAXJA# 2091
- MilkyWay Galaxy
I tried yesterday and today to monitor what temp CL starts, but the lm2 showed it staying in OL(even though it had went to CL and 14.7). I'll try resetting the lm2 and have the afr, cts, and OL on the same screen so I can at least tell by the afrs the exact temp it does this(I can record too, but should be able to catch it live). The lm2 does have it's limitations: I usually can monitor 4 obd2 parameters at once in addition to the afr(you can set priorities, etc)--any more and then it's too much for it to process and then you don't get accurate live data.
IIRC my son's Ford 96 Taurus goes CL in under 30 seconds from a cold start, if the sensors are good and working. But my memory could be faulty on this. I do recall reading that OBD-II and early HEGO O2 sensors were introduced so that cars could go closed loop in less than 30 seconds of engine start up to avoid air pollution since Cat converters need more than 30 seconds to get up to proper operating temperature.
I doubt the Cat or engine coolant gets very hot in 30 seconds.
What surprised me is that a lack of a working CTS sensor holds it closed loop.
Looking forward to seeing your posted results!
