ok so there is a pig tail behind the switch panel. plugged into the blank spot. i got the three switch panel and plugged it in. the switch lights up when the lights are on.
ok so i determined the pink wire is the dash lights. which leaves a black a blue and a purple. is black a ground? does anyone know which wires are the actually switched wires?
also just to make sure i wired them right i have 2 power wires from the 2 fogs run to a relay i have a supply wire from the batt to the relay. so the other 2 pins control the solenoid to switch the relay. so i need to take power to the switch and from the switch to the solenoid then the other pin would be ground right?
