FM/AM Radio won't come in now???
xj9687
Lancaster, PA
Ok so i have a sony head unit in my 96 cherokee. The radio wasn't always the best reception wise but it still came in pretty clear. So the other week I took apart my rear inside to spray sound deadener on the floors and walls. I also took off the door panels and sprayed those to. Now im not sure why but after i was all said and done i took it out for a spin. I turned on the radio to see if it made a different and all i got was fuzz. No matter what station all i get is fuzz except for 2 that come in when im sitting in my driveway and they go in and out depending on were u are standing. So my question is does anyone know why this is and if the sound deadening stuff or process may have knocked anything loose or what. I took the head unit out and messed around with it but nothing different. Any help would be greatly appreciated.
For some reason, the antenna cable has a connector in the middle. Looks a little like an RCA style connection. It's under the passenger dash, and you probably bumped it apart (it's spring loaded for some reason) while removing the trim panels.
