Blix
- Detroit Area - Roch Hills
Larger doesn't always mean better. If it flows water/coolant too fast, it doesn't have time to dwell and pick up heat. I don't know what you have or experience with exactly what you're describing, I'm speaking in general terms of heat transfer.
It's a good point Ecksjay, I should have elaborated. I doubt that it was an intentional restriction to slow down the flow, if it was it was a horrible place to put a restriction. You never want to restrict a cooling system at the inlet side. If you do then that means that you are creating a huge pressure drop right in an area that is already at the lowest pressure of the whole system. That means you could be taking an area that normally would be a bit below 14 psi (or whatever your system is set at) because of the "suction" of the pump, and then by the restriction dropping that pressure a few psi. So not only will it boil at a lower temp, it will boil right at the inlet to the pump and cause the pump to cavitate. Not good.
I am going to bring both pumps to work tonight and weld up a plate to the first pump, modeled after the Flowkooler. I'll take pictures and post them tonight/tomorrow, and I'll include a bit more of a write up about it.
Oh and I forgot to add; there is a small area on the flowkooler pump that is ground down, it looks like an area where a part number would be. I wonder if they just take someone else's pump housing and a stock impeller to make their pump.
