Ecomike
NAXJA# 2091
- MilkyWay Galaxy
Okay awesome, how long should it take for the marvel to work and notice some sort of difference? I'm sure every jeep is different but you know better then I do as you've used it before
I got far, FAR more change using the RPM trick on mine that I ever got with MMO, but the MMO over time, months or more may have helped clean up the sticky varnish, dissolve it so the RPM trick could work. I used MMO for about 2-3 years on my jeep before I learned about the RPM trick. That said I used it directly in the combustion chamber to clean the piston rings in my saturn and my oil consumption dropped from 1 quart/200 miles to 1 quart in 600 miles on the first use. I made a thread about here 2 months or so back.
