Flares: Rusty's, Bushwackers, None, Stock, YJ/TJ?
Which flares do you like w/35's and 6" lift
  • Rusty's
    Votes: 18 7.8%
  • Bushwacker
    Votes: 69 29.9%
  • Trimmed Stock Flares
    Votes: 32 13.9%
  • TJ/YJ
    Votes: 57 24.7%
  • None
    Votes: 55 23.8%
  • Total voters
    231
Status
Not open for further replies.
Anyone used or heard anything other than the flares spoken about here in this thread?
In the front I cut between 2 to 3 inches. Plus the pinch seam in the rear of the front fender has been cut and welded back so its all flat there. Any ways the front was the easy part; taped up the flare where I wanted it traced the inner lip and went to work with the cutoff wheel. Bolt on flare and its done. Well not that easy but close. You still have to trim it a little for the XJ body line at the bottom.
In the back it is cut a little over 3 inches probably, it is much more difficult. I basically have nothing left along the door and its cut a little higher behind the door. It is not very pretty in there but it works great. I can get some pics up for you guys later this afternoon, I'm at work right now. Plus the flares are back off for painting this weekend. Perfect for some detailed pics. I hope to have that all the painting done by sunday afternoon. Its been about two weeks since I drove it last. Prep work is a ____! (Fill in the Blank) But its ready to start spraying now.
I still have the pieces that I cut out of the front fender in the garage, I'm saving them so I can get pics to do a tech artical later on for some friends of mine down in Arkansas. I can post a pic of them also.
Did you leave most of the inner rear wheel tub or did you fit something larger? Years ago I had a friend that had a Pinto that he had turned into a 1/4 mile car, track only, and installed tubs in the back so that the rear wheels would fit. I was just wondering if you went to this extreme or if you managed to fit in some extra steel and just welded it in place.
Robert
was just curious about that last ?, hope to see an answer for it. about the tubs
Yes, I have Ford Explorer flares on my xj ,I easily clear 33's at 3 1/2 lift in the rear and 4 in the front, could probably do 35's.
Status
