when I had to terminate an upright at/through the floor on the race car, I found it stronger when I built a box under the flooring and ran the tube through the top of the box and welded it to the bottom and then seamed the top around the tube as well. Hard to explain, but one side of the box attached to the frame rail, the top attached to the floor, and the tubes welded top and bottom.
