I ran the 180 for a couple of years before the rebuild, when I went back to the 195 so I've got experience with both. One thing remains constant on mine no matter which stat I run; the temp will rise in the range of 10 to 30 degrees hotter when stressed. 10 over on hot days here and there but dropping back down quickly on deceleration, 30 over on very hot days climbing a long hill with a load for example. When the temp rises a lot I start the counteracting routine, you know AC off-heater on-backing off the speed etc.
30 over 190 (220F) isn't bad, 30 over 210 (240F) get's my attention. The motor run's fine with either temp stat, I even think a little better with the 180 but I don't like to make claims I can't back up, but with the lower one I'm not constantly watching the gauge wondering when it's going to shoot up. One thing for sure about a motor that starts to get hot, the hotter it gets the faster it climbs and the harder it is to get it back under control. Keeping it from getting to the hot end of the scale in the first place is worthwile IMO. I for one do understand that 210 is normal and that's what the factory engineered them to run at stock. The relative term here is STOCK, when we add weight, height,bigger tires,accessorys, age and so on, the limited cooling capacity becomes overworked pretty quickly. This I believe is how the 180 helps, at least in my experience. TC
