slabelle67
- Fischer, TX
98 Chrysler 8.25 (29spline), yukon 4.56, detroit locker. The backlash is set at 10, and the pinion shim is .011. What do I need to do?
Also, when I put load on the carrier bearings the gears will sometimes lock up - or only spin in one direction. It has the screw type adjusters on it, and I doing something wrong, or could it be the set up bearings on the pinion binding up?
