Fiberglass floor repair
gcam
alberta, canada
I haven't found anything about this doing searches...
Is it acceptable to repair holes in the floor up to 4" diameter with fibreglass, or does it have to be a weld in repair?
Thanks,
Geoff
You will have even more rust problems if you use fiberglass!!
Only if you don't do it right. I have helped patch dozens of floors with fiberglass over the years with no problems. Just don't try it over the CAT. :flame:
