Few things for sale, New... Axles, Ujoints, Outer billet tube seals, and gears
RWKHausSupply
Need to get rid of the following... These are all new and taking up room & $.
__________________________________________________ ___
2 - Ten Factory Outer axle stubs for all TJ, XJ, ZJ, WJ, YJ Dana 30 axles with the use of the larger 5-297x / 5-760x ujoint. Cut to allow full circle clips, a huge insurance that the clip(s) dont pop out prematurely and the caps fall out or spin.
99$ ea. These have a 10 yr warranty against breakage due to axle faliure.
2 - Alloy USA X-Joints new in the box. These are stronger then spicers and has grease fitting on each cap for flushing water/debis out of them.
35$ ea.
For some reason summit sells em for like 47$ ea. +10$ shipping.
http://www.summitracing.com/parts/ALY-11500/
X-joint is an aftermarket replacement U-joint for 5-297X & 5-760X U-joints. It’s made from forged 8620 gear steel, through hardened for increased strength. The cross is coated for added protection against wear. It comes packaged with full circle clips and grease fittings.
1 - Set Alloy USA Billet Aluminum Axle Tube Oil Seals
Keep water, mud and debris from entering your front axle housing. These CNC machined aluminum housings feature double sealing to provide that extra protection from the elements. Black Anodized finishe. Pair.
These at times will not fit stock axles. it really is hit and miss. but with any aftermarket inner axle set or full axle kit, they find nicely and do thier job well.
60$ for the pair.
1 - set of Motive gear 3.73 gears new in the box never installed and a master install kit.
150$ OBO. this is a steal. the gear set alone cost more then that. But its only a 3.73 so I dont expect to much hype over it.
all items can be shipped for shipping cost.
ok axle stubs and ujoints are gone....
